what is the difference between getElemet and getValue
Prasanthi1
Giga Contributor
What is the difference getElement() and getValue()?
Please tell me with examples..
Sushma Dhandge
Giga Contributor
Hi Prasanthi,
I hope below Example will clear your confusion
gr.setLimit(1);
gr.next();
gs.print(gr.getValue('assignment_group')); // how the direct field script looks
gs.print(gr.getValue('assignment_group.manager')); // Doesnt work
gs.print(gr.assignment_group.getValue('manager')); // Doesn't work
gs.print(gr.assignment_group.manager.getValue()) // We have to resort to the GlideElement version for dot walking
gr.getElement('assignment_group.manager').getValue(); // Closest alternative? But still using GlideElement
In the above script, we can see that the GlideRecord getValue accepts a string parameter but it can not be a dot walked field. For dot walking, we are forced to resort to the GlideElement version of getValue which does not accept a string value.
Please mark helpful if answer is correct.
sushma
9 REPLIES 9
Prasanthi1
Giga Contributor
We prefer getValue(), that is ok . I am asking that both functionality is same right or wrong? please tell me that one.
Thank You
Hi Prasanthi,
Functionality is different for both.
Murthy
Murthy
Hence please tell me the difference....
Hi Prasanthi,
document.getElementById() is a DOM manipulation method to get the element from HTML code with the Id. As id for every element is different it can be used to get that particular element by it's ID (more like a unique key).
But getValue() is used to return the value of the particular field.
Hope you understand now.
Murthy
Sushma Dhandge
Giga Contributor
Hi Prasanthi,
gr.setLimit(1);
gr.next();
sushma
