What is the difference between Parallel flow launcher and subflow(like a workflow is added in another workflow)?
Naveen Kumar
I need to know the difference between Parallel flow launcher and subflow.
And is there a problem if we use a workflow inside another workflow. Like if a task is there in the parent workflow and if the same task is there in the child workflow also, is there any problem.
Consider the parent as "new Hire/status change computer merged m3" and child as "procurement workflow v2".
Just for ex :if "T1" task is executed before Procurement workflow and same "T1" task is there in Procurement workflow also.
Is there any problem.
Hi @Bharath Kumar ,
Subflow activities run and manage workflows from a parent workflow.
The Parallel Flow Launchersubflow activity is available.
Hi @Bharath Kumar ,
Hi @Bharath Kumar ,
Any update to this ?Any follow-up required? if not
Kindly mark the answer as Correct & Helpful both such that others can get help.
Sandeep
