What is true about a page in portal?
Feroz1
What is true about a page?
a. Displays content via wigets
b. Can be used in any service portal
c. it is styled by theme
d. can only be used in one service portal
please tell me the answer if you know. Thanks in advance.
Mohith Devatte
Tera Sage
you can go with option A
usually pages contains row , containers ,columns and instances
each instance holds a widget and the content in the widget is rendered on the page
so no widget no content is displayed on portal page .
Use pages to organize content, ensure responsive mobile optimization, and design meaningful portal user experiences for your customers. A page houses containers and rows, which then contain widgets. By manipulating the layout of the page, and the widgets within it, you can construct your desired user experience.
DOCS EXPLANATION ABOVE !
PLEASE MARK MY ANSWER CORRECT IF IT HELPS YOU
1. Which record describes the behavior and source of searchable data within a service Portal
a. Search Facet
b. Search Source
c. Facet Filter
d. Search page
2. What element do you configure to allow message to be broadcast to service portal users?
a. header
b. search source
c. page route map
d. Announcement.
Can you please help me with this?
Hello ,
is this a service now exam that you are taking ?
if yes we are not supposed to answer here in this forum
if not raise a new question and tag me i will be definitely helping you
but make sure this is not some service now exam and i am assuming this is some general exam
thanks
Some question by one MNC company asked me in test on portals
okay then fine !
please raise a new question will help you and tag me as there are multiple questions in the thread
