when a catalog item request is submitted a notification will be triggered to the requestor. We have a field where the requestor can enter multiple email id's as shown in snippet. Now we need to send notification to all the mentioned email id's includ
Neelu S
when a catalog item request is submitted a notification will be triggered to the requestor. We have a field where the requestor can enter multiple email id's as shown in snippet. Now we need to send notification to all the mentioned email id's including the requestor. How can we achieve that
No your event Queue declaration needs correction we can send only two parameters in events
push your requested for email also into the array like below
var emails = current.email_address.split(',');
emails.push(current.variables.requested_for.email.toString());
gs.eventQueue('signavio.request.created' ,current,SON.stringify(jsonObject),emails );
I am sending your resuested for emails and the other emails also at a time  in one parameter instead of multiple
please accept the solution if you find it helpful
Please use the below script in workflow activity only as you are triggering your event in workflow activity
var emails = current.email_address.split(',').toString();
pass this emails as a parameter to the event and check recepients in parm1 in notification.
Please accept the solution  if you find it helpful
gs.eventQueue('signavio.request.created', current, current.variables.requested_for.email,JSON.stringify(jsonObject),emails);
is this correct?
