When I click on Flow Context in RITM it does not show the flow. Can someone please guide on what is the proper settings.
Nolan4
I have set the property to TRACE still it doesn't load the flow and keeps showing the message - Flow reports not available. Check system property com.snc.process_flow.reporting.levelOpen Context Record
PFA images for details.
Hi Nolan,
It is same infact just updating this property to ON worked for me.
Can you try clearing your cache once?
If it still dont work I will suggest to get one HI case raised.
Thank you
Prasad
Prasad Pagar
Hi Nolan,
Ideally it should work. Did you tried with 'ON' choice?
https://docs.servicenow.com/bundle/rome-servicenow-platform/page/administer/flow-designer/task/enable-flow-reporting.html
Thank you
Prasad
Yes, I have tried but it didn't work.
Do you have any other entry in Process Automation->Settings ? PFA.
Hi Nolan,
Thank you
Prasad
Geoff_T
In my PDI I set up as follows and it works:
Just to clarify - is your 'Value' set as 'ON' like in screenshot above?
Geoff
