When I click on Flow Context in RITM it does not show the flow. Can someone please guide on what is the proper settings.
Nolan4
I have set the property to TRACE still it doesn't load the flow and keeps showing the message - Flow reports not available. Check system property com.snc.process_flow.reporting.levelOpen Context Record
PFA images for details.
Hi Nolan,
It is same infact just updating this property to ON worked for me.
Can you try clearing your cache once?
If it still dont work I will suggest to get one HI case raised.
Thank you
Prasad
Nolan4
Thanks guys. ON worked.
