Why does my published report not show data from dot-walked fields?
Steve Chapman
Good day all,
My manager has tasked me with creating a report that a multitude of users can view generated mainly out of Change Request fields.
There is however 1 field (Business Service from the Impacted Services table) that is required to be in the report also.
Because I couldn't dot-walk to the business service field from the change request table, I dot-walked to all the change request fields from the Impacted Services table and in that report view all looks fine.
The problem I am having is that the data for the dot-walked fields disappears when the report is viewed via the published link, is this an inherent existing ServiceNow issue or is it pretty clear that I have done something wrong or not done something??
Many Thanks for any help as soon as is possible
Kind Regards
Steve
12 REPLIES 12
Thanks Chuck,
I have -   a table level read ACL for public
                    -   a table * read ACL for public with a condition set to false.
                    -   field level read ACL's for public.
Does this sound about right??
Steve
check the acl's on the field that is not showing...
there are a couple of things to consider here.. when you publish a report it creates a publicly available link.. meaning people NOT logged into ServiceNow can view the report.... so when you are testing you have two cases to test... 1> a user that is signed into Snow... and 2> a user NOT signed into Snow   you need to be clear when clicking the link on the published report and looking at it are they logged in or not....
Pradeep Sharma
Hello Steven,
Can you turn on the ACL debugger and make sure that the user has access(READ ACL's) to the referenced table record.
http://wiki.servicenow.com/index.php?title=ServiceNow_Access_Control
