Workflow's condition "Runs always" doesn't work when task_sla table is selected
nadia78
Giga Contributor
I'm trying to create a Workflow from "task_sla" table to trigger a notification when Slas reach 100%.
I already saw a native Workflow which triggers notifications when Slass limit reach 50, 75 % and 100 % but when I copy it, and I modify the properties to "run always", condition is not saved. May be because of the task process.
I waiting for your anwsers,
Best regards
Dubz
Why are you copying the native workflow? Can't you just use the event that is generated in that workflow to trigger your notification?
nadia78
Giga Contributor
Thank you David for your awnser, now I use the Default SLA Workflow and let "active" only the notifications I need (notifications linked to each event)
Glad it's working for you now, could you mark my answer correct to close this thread down?
