07-13-2022 12:43 AM
Hi all,
while we editing the knowledge article is there any way to see the content of knowledge block associated with that knowledge article with in article body instead opening the kb block in separate tab.
In the above picture there are 2 kb block inserted in to article instead number of kb block is there any way to see the content of the kb block inside the knowledge article body
Saranya K
Knowledge Management
- 3,072 Views
07-13-2022 02:35 AM
That's not possible, You may have to paste KB block content in KB article body other than that you cannot do much.
Mark my answer as correct if that helps
07-13-2022 02:35 AM
07-18-2022 01:56 AM
Hi
please provide me any article or document for a reason why it is not possible
Saranya K
07-18-2022 02:48 AM
I don't have any doc to share but you can check with Servicenow HI support team once if you have customer account. Mark my answer as correct if that helps
07-16-2022 11:02 AM
If you are fine with my reply, Please mark my answer as correct and close the thread.
