07-13-2022 12:43 AM
Hi all,
while we editing the knowledge article is there any way to see the content of knowledge block associated with that knowledge article with in article body instead opening the kb block in separate tab.
In the above picture there are 2 kb block inserted in to article instead number of kb block is there any way to see the content of the kb block inside the knowledge article body
Saranya K
Knowledge Management
- 3,072 Views
07-13-2022 02:35 AM
That's not possible, You may have to paste KB block content in KB article body other than that you cannot do much.
Mark my answer as correct if that helps
07-17-2022 03:27 PM
Hi, I haven't used Knowledge Blocks but I'd hope they show their content when you press 'view article' under related links.
Does that work? If it doesn't I feel like it would be a good idea for the idea portal.
