08-23-2022 03:45 PM
Is there a report I can run to find "broken links" in article bodies and on the ESC portal? Example: a published article posted a hyperlink in the article body to another article that has been retired. When the user clicked on the retired link they get an error. How can I proactively run a report to find broken links such as this that reference outdated or retired articles?
Knowledge Management
- 5,720 Views
08-25-2022 03:22 PM
Hi Liz,
Here is another post on this I saw recently https://community.servicenow.com/community?id=community_question&sys_id=4dae1c3adb9c9110b5d6e6be1396...
And here is the idea that has already been submitted and closed as "In Consideration" in the idea portal. If you can still vote on it I'd suggest you add your vote there rather than create a new idea as they'll just mark it as a duplicate.
There is an idea that could use more votes to show its importance.
Knowledge articles need automation to find bad urls/bad email addresses: https://community.servicenow.com/community?id=view_idea&sysparm_idea_id=7a2ec28fdb079c106621d9d96896...
Hopefully, we'll get this in Vancouver as Jaime has said.
01-30-2023 11:21 AM
There is a simple report you can run on articles before they are retired that lists any other articles linked to it. What I've begun doing is running the report first and then removing or updating the link.
The report has these conditions, all of which must be met:
Knowledge base is Support AND
Status is Published AND
Article body contains (KB number of article being retired)
07-24-2023 02:39 PM
@jaimehonaker - I am interested in this feature. Do you know if it is going to make the Washington release?
