How to create interactive filter in UI BUILDER same as dashboard?
kishorkumar
Hi Folks,
        I need to create a reports in ui builder and also need to create a interactive filter if i change anything in the filter the reports update the same? Can anyone help with this requirement.Screenshot 2023-08-07 115944.pngScreenshot 2023-08-07 120852.png
Hi @Vrushali11
Have you got solution for this because i am also structed up showing the group members please help me if had done it
Hi You can find step by step instruction how to connect filter to data visualisation in UI pages here: https://developer.servicenow.com/dev.do#%21/reference/next-experience/utah/shared-components/sn-comp... (scroll down to section "Connect the filter to data visaulization component")
Olga
Hopefully you had already figured this out in the meantime, but it appears that you did not select anything for 'data to filter'. So you have your filter source, the user table, but then you also need to specify on which field you want to apply that filter! So you could for example use 'user' to filter 'assigned to'. But it seems that in your case you need to use a cascading filter. Configure a Single/Multiple select or cascading filter in the in-line editor
If you have a dashboard created with the inline editor, how do you display this in a workspace? (I have made sure to add the workspace in the dashboard visibility field).
You need to create a new page in your workspace from a template called "dashboards". Here is the doc with details: https://docs.servicenow.com/bundle/xanadu-now-intelligence/page/use/performance-analytics/task/add-d...
