How to Move Container Component in UI Builder
triciav
How do you move a component either out a level or to another container component?
I need to move the Label Value Stacked 2 and the Card Base Actions 1 at the same level as the Metadata and not underneath it.
There is no way to move these ? without having to recreate them?
This is Soooo FRUSTRATING
Thank you
Hi @triciav ,
You can refer to this blog which should help you :https://community.servicenow.com/community?id=community_blog&sys_id=f97a132ddbeaa4507d3e02d5ca96191f
Sandeep
Hi @Brad Tilton , so you are saying Drag&Drop in Component Tree should be available from Tokyo? So we can mark that idea as implemented?
Martin76
The easiest for now (for me) is to go to the Page definition record in UI16 and modify the JSON directly. I have submitted an idea: Drag&Drop in Component Tree to make the process easier using the left-pane component tree and as I'm reading the answers here, this should be finally available in the upcoming release.
But for now, I suggest using a good IDE or JSON editor and modify the page definition's composition field.
