How do you find max length for reference fields?
OKayKay
Hi, I am new to ServiceNow and trying to navigate my way to build reports. I had a quick question about max length for reference fields. I know it will always be 32 for reference type fields, but there is a way to look at backend and find a 'true' max length for these fields. Can anyone show me how I can get to that page?
Thanks in advance!
JaishreeR
Hi @OKayKay
First of all welcome to the servicenow world.
Coming to your question - For example , let's find the true length of caller field in incident table. The caller field is referencing the user table , hence go to the user table --> show schema map and in the columns select Name --> you will find the true length.
Screenshot attached
