Help with metric script
veronica_malmo
Kilo Expert
I have a metric script that should calculate the duration from a change is created and to it's in the state: proposed, sub_state: awaiting_customer_proposal, but something is not working with it. I'm not the one that has created this metric in the first place, I just hoped I could use it.. can anyone see any obvious mistakes?
// variables available
// current: GlideRecord -   target Change
// definition: GlideRecord -   (this row)
var s = current.state;
var ss = current.u_sub_state;
// We attach a metric when Change is created
if (current.sys_updated_on == current.sys_created_on)
createMetric();
// If Change state reaches Proposed and Sub-State Awaiting Customer approval we close the metric.
if(s == -7 && ss == 'awaiting_customer_approval')
closeMetric();
function createMetric() {
var mi = new MetricInstance(definition, current);
if (mi.metricExists())
var gr = mi.getNewRecord();
gr.start = current.sys_created_on;
// gr.end = current.sys_updated_on;
// gr.duration = gs.dateDiff(gr.start.getDisplayValue(), gr.end.getDisplayValue());
gr.calculation_complete = false;
gr.insert();
function closeMetric() {
var gr = new GlideRecord('metric_instance');
gr.addQuery('id', current.sys_id);
gr.addQuery('calculation_complete', false);
gr.addQuery('definition.type','calculation');
gr.addQuery('definition',definition.sys_id);
while(gr.next()){
// gs.log("==>>DEBUG. Found existing Problem metric. Updating");
// gs.log("==>>DEBUG. closing: "+ gr.definition.name+" for: "+ current.number);
gr.calculation_complete = true;
gs.log("==>>DEBUG. CHANGE KPI Start: " + gr.start.getDisplayValue());
gs.log("==>>DEBUG. CHANGE KPI End: " + gr.end.getDisplayValue());
gs.log("==>>DEBUG. " + gr.duration);
gs.log("==>>DEBUG. Updating Metric: " + gr.id);
gs.log("==>>DEBUG. current.sys_id: " + current.sys_id);
// var definition =new GlideRecord('metric_definition');
// definition.get(gr.definition);
// var mi =new MetricInstance(definition, current);
// mi.endDuration();
gr.update();
Is the metric created but not closed?
closeMetric();
If so, is your condition awaiting_customer_approval set in the same update as when it is set to state -7?
The script is only called when substate changes, so it needs to be in the same update.
Otherwise, consider moving the close logic to a BR.
No, the metric is not even created..
Other metrics are working? Then I would add some logging, like   gs.log("Metric fired","metricdebug")
Perhaps I'm trying to do something impossible in metrics? When I try to do a metric with calculation on only State from Created to State proposed everything works, it is when I try to calculate the duration in several states PLUSS a substate in the last state that everything stops working..
So perhaps I have to do one metric to calculate the States duration and one for the substate, and then add them up..
