Integration Hub / Spokes
abdelkadergh
I’m designing a Flow with more than 10 actions, but I know there’s a 10-item limit in Flow Designer. I’ve heard Subflows can help, but I’m not sure how to structure them for reuse across different Flows. Can someone provide a best practice example?
AnjalPDijo
Hi @abdelkadergh ,
When designing a Flow with more than 10 actions, you can overcome the limit by using Subflows.
Best Practice Approach:
  • Create a Main Flow for the overall process logic.
  • Identify steps or tasks that are repetitive or logically grouped and move them into a Subflow.
  • Subflows allow you to define inputs and outputs, making them reusable across different Flows.
  • This modular design improves maintainability, readability, and avoids hitting the 10-action limit.
For detailed guidance, refer to the official documentation: Subflows in Flow Designer
Hope this helps!
Best regards,
Anjal
Ankur Bawiskar
@abdelkadergh
you can use combination of action and subflow for this.
what did you start with and where are you stuck?
