Custom License Metric for ILMT integration with ServiceNow
markt-f5
Hi there
I need to create Custom License Metrics in ServiceNow for the below IBM metrics and need to know how the script for calculating the metric was put together. Any insight here would be much appreciated!
1) Floating User Single Install
2) Managed Virtual Server (MVS)
3) Per Establishment
4) Workspace Add-On Authorized User
5) Terabyte
Thanks for the response, We will use V2. Could you please help me understand where to begin with.
As per my understanding the below steps need to be completed by the the client(Or IBM vendor)
  • Install, set up, and run ILMT or BigFix Inventory on a physical host or virtual machine (VM).
  • Install ILMT version 9.2.24 or later.
  • Configure your IBM ILMT agents to scan your physical hosts or VMs in compliance with IBM usage measurement guidelines.
  • Enable ILMT or BigFix Inventory to discover the configurations of both physical hosts and VMs as well as the relationships between them.
  • Classify and bundle IBM components into IBM products through ILMT or BigFix Inventory.
And below steps need to be completed in Servivcenow
Kindly confirm
This is correct!
Best, Dennis
