Jira SAM Integration - Connection Validation Failing Despite Successful OAuth Token
02-25-2026 03:17 AM
I hope you are all keeping well.
I am trying to build the Jira Software Integration with Software Asset Management (SAM) to download subscriptions, pull user activity, and reclaim subscription information in Software Asset Workspace. I have been following the ServiceNow documentation carefully.
Documentation: https://www.servicenow.com/docs/r/washingtondc/it-asset-management/saas-license-management/integrate...
Environment:
- ServiceNow instance: Wellcome (Yokohama DC release)
- Jira Spoke version: 4.1.0+
- Authentication method: OAuth 2.0
- Jira site: wtprojects.atlassian.net
What I've done so far:
- Created an OAuth 2.0 app in the Atlassian Developer Console (ServiceNow-JiraSaaS)
- Configured all 9 required granular scopes (read:application-role:jira, read:group:jira, read:user:jira, read:avatar:jira, read:audit-log:jira, read:issue-details:jira, read:field-configuration:jira, read:issue-meta:jira, write:group:jira)
- Set the callback URL to match our ServiceNow redirect:
https://wellcome.service-now.com/oauth_redirect.do - Created the integration profile (Jira SaaS) with Connection & Credential alias:
sn_jira_spoke.jira_subscription_activity_reclaim - Created the HTTP(s) Connection with URL:
https://api.atlassian.com/ex/jira/<Cloud-Id> - Confirmed the Cloud ID is correct via
_edge/tenant_info - OAuth Entity Profile is linked to the credential record
- Successfully obtained an OAuth refresh token (valid until 05/06/2026)
- My Atlassian account has site admin permissions
The problem: When I click Validate Connection on the integration profile, I receive: "Connection validation is not successful. Please check connections and credentials and try again."
What I found in the logs:
- Outbound HTTP Log shows a GET request to:
https://api.atlassian.com/ex/jira/<Cloud-Id>/rest/api/2/group/member - Response status: 404
- Response body: "Client must be authenticated to access this resource."
So it appears the OAuth token is not being attached to the outbound API requests, even though the token exists and is valid. The 404 with an authentication error suggests the Bearer token is missing from the request header.
What I've already tried:
- Re-authorizing the OAuth token via Get OAuth Token
- Verifying the OAuth Entity Profile is linked to the credential record
- Confirming only one active connection exists on the alias
- Setting
com.glide.transform.json.max-partial-lengthto 32768 - Enabling
glide.outbound_http.logfor debugging
Has anyone encountered this issue before? Any suggestions on how to ensure the OAuth token is included in the outbound requests would be greatly appreciated.
Thanks in advance.
05-12-2026 04:45 PM
My recommendation is to re-create the profile.
05-12-2026 12:03 AM
Hi @Masum172
Can you add offline_access scope in your Oauth profile and update the token.
Also as per documentation:
Select Edit Scopes to add the following scopes:
- read:application-role:jira
- read:group:jira
- read:user:jira
- read:avatar:jira
- read:audit-log:jira
- read:issue-details:jira
- read:field-configuration:jira
- read:issue-meta:jira
- write:group:jira
also ensure, Jira Role having this permission: Refer the Minimal user permissions table.
Tanushree Maiti
