Prerequisites for SAP Integration with ServiceNow SAM Pro
TanayB
Hi all,
I’m currently exploring the integration of SAP with ServiceNow’s Software Asset Management (SAM) Pro and would greatly appreciate insights from those who have experience with this process.
- Are there specific SAP modules, versions, or configurations required for compatibility with SAM Pro?
- Does the integration require a middleware (e.g., SAP PI/PO, CPI) or third-party tools?
- Are there specific ServiceNow plugins or MID Server configurations needed?
- What SAP roles/permissions or RFC setups are necessary for data extraction?
- Are there recommended SAP tables, transactions, or APIs (e.g., BAPIs) to prioritize for license/usage data?
- Are there specific tables, fields, or workflows in ServiceNow that need customization to align with SAP data?
- How is SAP license metric data mapped to ServiceNow’s normalization processes?
- What challenges might arise during the integration, and how can they be mitigated?
If you’ve worked on a similar integration or have documentation/guides to share, your input would be invaluable! Even pointing me toward relevant ServiceNow docs, SAP notes, or community threads would be immensely helpful.
Thank you in advance for your time and expertise. I look forward to learning from your experiences!
Best regards,
Tanay
dreinhardt
Hi @TanayB,
please check the following ServiceNow sources about the SAP integration
--> check the ServiceNow store link for your release
--> No, it's based on a ABAP tool for the SolutionManager and uses RFC connections to get the data
--> Access MID to SAP SolMan is requiered
--> see attached PDF
--> No, publisher pack covers all
--> Covered by SAMP based on named user types & engine measurements
--> Table details are here with more content - Tables installed with the SAP publisher pack
--> start with a small test of RFC connections (1-2) to avoid long-running tests
--> SSL certificate chain should match between all systems
--> Missing engine types must be reported to SN content team
Hope this helps!
Best, Dennis
Should my response prove helpful, please consider marking it as the Accepted Solution/Helpful to assist closing this thread.
Hi @TanayB,
please check this post about some details based on the latest Yokohama release and SAP Cloud
How to integrate With SAP Cloud to bring license v... - ServiceNow Community
Best, Dennis
MateoB
@dreinhardt  Dear @dreinhardt , do you have any topics to not miss because of licensing of SAM Pro. Do we have something special to consider. Is there any special SKU for the SAP integration to consider.. I dont found any valuable topics in the docs.
Hi @MateoB, no - all publisher packs and integrations art included in your SAM Pro subscription.
Best, Dennis
Thank you Dennis for the fast answer.
