Help text of a catalog field is center aligned
01-12-2026 11:52 AM
Hi Community.
I am working on a record producer and starting this week, I am seeing that the help texts we add to any field is kind of in the center instead of left aligned. This was not the case last week. They were aligned left (kind of in the same level as field name, just below). I am attaching an image of one of the fields and the help text which is center indented. Does anyone know of the issue and how to left align it? The yellow strip is from where I want the help text to appear.
Any help is very much appreciated.
01-12-2026 09:32 PM
then please check that first and raise case with ServiceNow if it's upgrade issue
01-19-2026 01:53 AM
We have also been experiencing this issue with a customer for a few days.
Have you opened a ticket with ServiceNow?
01-19-2026 10:09 AM
I am not sure if client opened any ticket or not. I reported that the issue isn't custom and it is happening with every portal: CSM, ESC, etc. But I guess you have to raise a ticket to get proper solution.
