‎02-27-2025 04:53 AM
Due to some reason Notification not working for some user from [x] company in SIR application. The notification is created when record insert. The record is generated by record producer which creates a SIR when submitted.
I cheeked the user preferences its enable. The sent notification is enable as well.
Please where i can debug and update the configuration.
thanks.
‎03-03-2025 11:29 PM
Thanks for all to response on my query, finally got the cause of the problem, it was Domain separation causing to event not to triggered.
‎02-28-2025 04:04 AM
In that case we may need to connect
Thank You!
‎02-27-2025 05:38 AM
I checked all the condition they are correct, users are active, user preferences is enable. One more thing i catch when i test with user A by implementing in DEV its not trigger the notification and when test in UAT it working. I check the role if it affecting but have the same profile/role in both instance.
