Vulnerability Response job "Process Vulnerability Solution Metrics Queue" taking days to complete
dan167
Hey everyone,
We have vulnerability response setup with multiple integrations. After setting up our most recent integrations "Tenable" and "Microsoft TVM" I am seeing a job that is running for days. The job name is "Process Vulnerability Solution Metrics Queue". When I cancel it, it starts back up. Does anyone have any knowledge on how long this should be taking to complete or timeout? Where should I check for issues with this job?
I have not been able to find much on this in my searches.
15 REPLIES 15
will do. Thank ya
Sangeetha_Jegan
Hi @dan167 , Is there any update to this? Did the ServiceNow support help you reduce the run time of the job? I am stuck with similar issue and job is running for more than 2 days now.  My configurations are similar to yours -
1. VR application version - 25.0.7
2. The system property sn_vul.populate_scanner_solutions is set to false
3. Handling roughly around 1M VITs
Thanks in advance.
They opened have a problem ticket opened on this issue PRB1807050. SN said that the job taking a long time to complete is a known issue and they will be trying to improve the feature in a future VR release. Date TBD.
For me the job does complete at some time but takes multiple days. Right now, the transaction has been running for almost 3 days.
Sangeetha_Jegan
Thank you so much for the quick response! Hope one of the future releases take care of this!
TanayaGavande
Hi Dan,
Does the instance use domain separation? If so, it might be because the job created in a domain might not have the 'Run as' user from the same domain. Let me know if that's the issue.
