how to add two functions from script include in a reference qualifier
akhila13
SeatUtils is the script include and  getbcp3() is a function. i have another function getbcp2()
have to call both in single reference qualifier
tried javascript:new SeatUtils().getbcp3()+new SeatUtils().getbcp2(); but not working fine
hvrdhn88
Giga Patron
use this to call function inside script include
eg this.functionName()
I have two function and want to merger both result into third function it will be used like below.
get1: function(){
return 'hello';
get2: function(){
return 'harsh';
final: function(){
return this.get1()+','+this.get2();
If my answer helped you, kindly mark it as correct and helpful.
12 REPLIES 12
Dhananjay Pawar
Is it working with single function?
yes... when we call both as single function its working
Then your reference qualifier should work.
Try adding scope before script include name.
javascript: new global.SeatUtils().getbcp3() + new global.SeatUtils().getbcp2();
Note - Replace global with your scope name and try.
Swapnil Soni1
Giga Guru
  • Check that the script include is available to all scopes (it's in the upper right of the form)
  • address your script include with the scope name prefix. E.g. javascript:new myscope.myScriptInclude().myFunction()
Let me know if this helps.
  • i have changed the application scope.. Still it not working
