How to Create Problem task record on problem table with script
IbrahimVali
How to Create Problem task record on problem table by using script in ATF.
I have used this method, It is creating a record in problem task table but, not able to relate with particular problem in ATF.
var tasktable = new GlideRecord ('problem_task');
tasktable.initialize();
tasktable.short_description = 'round1';
tasktable.problem = ('sys_id', current.sys_id);
tasktable.insert();
there is a field 'problem' in the problem task record write, in that I need to be get that related problem number.
Thanks.
IbrahimVali
Found a correct answer:
Flow A:   1. Open, 2. Set field Values, 3. Submit (Problem record on 'problem' table);
Flow B:   1. Open, 2. Set filed Values (problem field= give the reference of problem record which is                                     submitted previously), Submit (Problem Task record on 'problem_task' table)
 Flow C:   Run test, you will get related problem number on problem task record.
Thanks.
If the current  object is referring to the required problem record then use this:
tasktable.problem = current.sys_id;
tasktable.insert();
This is also not working.
Thanks.
IbrahimVali
Thanks.
blanca12
Mega Contributor
Try this:
Lucky Patcher 9Apps VidMate
