Auto populate reference variable based on another reference variable on a catalog item form. I have reference variable Application referring to 'Name' field on Applications (cmdb_ci_appl) table and another list field called 'Roles' in it. On catalog
‎09-28-2020 05:12 AM
Auto populate reference variable based on another reference variable on a catalog item form. I have reference variable Application referring to 'Name' field on Applications (cmdb_ci_appl) table and there is a list field called 'Roles' on same table, which has multiple roles associated to each application (these roles are maintained in a separate custom table). On catalog Item I want to populate roles from this list field values in a variable based on the application selected on catalog form.
Hope someone helps me get this! Thank you
Service Catalog
‎09-29-2020 10:57 PM
recommended is Client Script + GlideAjax
Script Include: It should be client callable
var checkRecords = Class.create();
checkRecords.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getDetails: function(){
var sysIds = this.getParameter('sysparm_ci');
var arr = [];
var gr = new GlideRecord('cmdb_ci_appl');
gr.addQuery('sys_id', 'IN' , sysIds);
while(gr.next()){
arr.push(gr.u_security_roles.toString());
return arr.toString();
type: 'checkRecords'
Client Script:
if (isLoading) {
if(newValue == ''){
g_form.clearValue('security_roles');
var ga = new GlideAjax('checkRecords');
ga.addParam('sysparm_name', "getDetails");
ga.addParam('sysparm_ci', g_form.getValue('variableName')); // give here variable name
ga.getXMLAnswer(function(answer){
if(answer != ''){
g_form.setValue('security_roles', answer); // give here user_id variable name
‎09-29-2020 11:57 PM
Hi Ankur,
Below are my script include and Client Script, its still the same shows all roles on portal when application is selected and shows there is a javascript error in this browser console
Script Include
var securityroles = Class.create();
securityroles.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getRole: function() {
var name = this.getParameter('sysparm_appname'); // aapplication variable name
var arr = [];
// if (name != '') {
gr.addQuery('sys_id', 'IN', name);
while (gr.next()) {
type: 'securityroles'
Client Script
if (isLoading) {
if (newValue == '') {
var ga = new GlideAjax('securityroles');
ga.addParam('sysparm_name', "getRole");
ga.addParam('sysparm_appname', g_form.getValue('u_security_roles'));
ga.getXMLAnswer(function(answer) {
if (answer != '') {
‎09-30-2020 12:06 AM
what browser console error?
what came in the alert?
alert(answer);
if (answer != '') {
‎09-30-2020 12:07 AM
can you update client script as this
if (isLoading) {
ga.getXML(callBackMethod);
function callBackMethod(response){
if (answer != '') {
‎09-30-2020 12:59 AM
Hi Ankur,
It's still the same, Security roles list collector field shows all values and throws 'There is a JavaScript error in your browser console' error.
