Auto populate reference variable based on another reference variable on a catalog item form. I have reference variable Application referring to 'Name' field on Applications (cmdb_ci_appl) table and another list field called 'Roles' in it. On catalog
jyotsna1
Giga Contributor
Auto populate reference variable based on another reference variable on a catalog item form. I have reference variable Application referring to 'Name' field on Applications (cmdb_ci_appl) table and there is a list field called 'Roles' on same table, which has multiple roles associated to each application (these roles are maintained in a separate custom table). On catalog Item I want to populate roles from this list field values in a variable based on the application selected on catalog form.
Hope someone helps me get this! Thank you
16 REPLIES 16
Can you share what browser error?
Also did you use proper variable name to set the value on form
jyotsna1
Giga Contributor
Hi Ankur,
Below is the error
Variables Below
Catalog Client Script
if (isLoading) {
if (newValue == '') {
g_form.clearValue('security_roles');
var ga = new GlideAjax('securityroles');
ga.addParam('sysparm_name', "getRole");
ga.addParam('sysparm_appname', g_form.getValue('u_security_roles')); // u_security_roles is field name        from cmdb_ci_appl table
ga.getXML(callBackMethod);
function callBackMethod(response){
if (answer != '') {
g_form.setValue('security_roles', answer);
the variable should be application and not u_security_roles
correct this line
ga.addParam('sysparm_appname', g_form.getValue('application'));
try adding alert for answer
alert(answer);
if (answer != '') {
jyotsna1
Giga Contributor
Hi Ankur,
Sorry! Its the same even after correcting
if (isLoading) {
ga.addParam('sysparm_appname', g_form.getValue('name')); // Application field name from cmdb_ci_appl table
alert(answer);
if (answer != '') {
I got this working with below
Client Script
if (isLoading) {
g_form.clearValue('security');
ga.addParam('sysparm_appname', newValue);
// alert(answer);
if (answer != '') {
g_form.setValue('security', answer);
Created a new free text field 'Security' populated values into it and the got them in to list collector field
Reference Qualifier
javascript:'u_security_roleIN'+current.variables.security;
