Error with calling script include in flow designer
Smriti Rastogi
I have a script include with this syntax
var testScriptInclude = Class.create();
testScriptInclude.prototype = {
            initialize: function(currentObj) {
            this.currentRecord=currentObj;
generateDataFields:function(){
var fields = {
'dataone':'',
'datatwo':''
// some logic to populate data1 & data2
return fields
I am calling this in inline script in flow designer -
var obj=new global.testScriptInclude(fd_data.trigger.current);
var data = obj.generateDataFields();
return data['dataone'];
Error: undefined is not a function.,Detail: undefined is not a function.
Any clue what I am doing wrong.
Also the same works in background script.
11 REPLIES 11
I usually test my scripts with "Scripts - Background" using "gs.info()" or with Script Include because it's much easier to debug.
FYI, I've tested the script in question with Scripts - Background and it worked without problem. Try commenting out the "some logic" codes to see if it works. If there's an error, it may be with the input/output variable settings.
yes it works with background script but not in flow designer.
Smriti Rastogi
The script ran perfectly fine with a custom action.
Not sure what the issue was with inline email script.
Hi
nice to hear, that you could solve your problem by yourself!
Kind regards
Maik
