Error with calling script include in flow designer
Smriti Rastogi
I have a script include with this syntax
var testScriptInclude = Class.create();
testScriptInclude.prototype = {
            initialize: function(currentObj) {
            this.currentRecord=currentObj;
generateDataFields:function(){
var fields = {
'dataone':'',
'datatwo':''
// some logic to populate data1 & data2
return fields
I am calling this in inline script in flow designer -
var obj=new global.testScriptInclude(fd_data.trigger.current);
var data = obj.generateDataFields();
return data['dataone'];
Error: undefined is not a function.,Detail: undefined is not a function.
Any clue what I am doing wrong.
Also the same works in background script.
11 REPLIES 11
I had this idea of using custom action as a last option.
But odd how the inline script did not work.
Radek
Hi, had the same issue in Vancouver - undefined, new global.NameOfScriptInclude()
it turned out - if it's under if condition than it's undefined..
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0791144
Workaround:
1. define flow variable in the body of the flow + use the script include (I haven't tested subflow which could be used as well)
2. use the defined flow variable in the action
