execute script include from action script on flow designer
07-07-2020 01:29 PM
hey there,
i have a Flow and on that flow i am running an action.
the action as inputs, script, outputs.
on the script i want to call script include and get answer
my code is - it looks like the script include not getting like this: global.TranzillaUtil(); and because of that i am thinking its not executing. help??
//call scriptinclude
var SI = new global.TranzillaUtil();
var result = SI.CreditChargeByInvoice(inputs.card_id,inputs.account_id,inputs.invoice_total_amount);
outputs.responsecode = result;
})(inputs, outputs);
Flow Designer
08-20-2020 02:58 PM
Can you place log inside your script include function updateGroup() and see what you get? If possible, can you share the screenshot of your script include?
02-01-2024 02:49 AM
Hi, had the same issue in Vancouver - undefined, new global.NameOfScriptInclude()
it turned out - if it's under if condition than it's undefined..
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0791144
Workaround:
1. define flow variable in the body of the flow + use the script include (I haven't tested subflow which could be used as well)
2. use the defined flow variable in the action
