Field decorations / Reference contributions not working for certain (reference) field
‎04-01-2022 02:34 AM
I have a working UI Macro on the incident form which sets the assignment group field to the support group of the currently selected CI.
When I add it as field decoration / reference contribution to for example the customer (reference) field, it shows on the form, and does exactly what I want it to do.
When I add it to the assignment group (reference) field, it does not show.
Does anyone have an idea how to fix this?
With kind regards.
‎04-01-2022 03:05 AM
so what happens when you add it to assignment_group field?
does it not show up?
regards
Exactly. It does not show.
‎04-01-2022 03:07 AM
did you check any browser console error?
can you share the field configuration for assignment_group on how are you adding the macro?
it would work for reference field
‎04-01-2022 03:10 AM
other fields are in which scope and assignment_group is in which scope?
are all those 3 fields on same table?
