Field decorations / Reference contributions not working for certain (reference) field
04-01-2022 02:34 AM
I have a working UI Macro on the incident form which sets the assignment group field to the support group of the currently selected CI.
When I add it as field decoration / reference contribution to for example the customer (reference) field, it shows on the form, and does exactly what I want it to do.
When I add it to the assignment group (reference) field, it does not show.
Does anyone have an idea how to fix this?
With kind regards.
04-01-2022 06:05 AM
Did not work. I had this same problem a while ago with another UI Macro. It also does not work for the field cmdb_ci. So I think it has something to do with the field itself, but I have no clue what the problem is..
04-01-2022 07:26 AM
Sorry we don't know the actual configuration in your instance.
So you will have to debug from your side.
03-18-2025 07:32 AM
Did you check the override record does not have an override set for the attribute?
