07-25-2024 07:40 AM
has anyone experienced this error when activating a Flow in the Flow designer?
I can change and save my flow. I can test the flow, but I can't activate my flow.
I'm on the Washington DC version patch4-hotfix1
07-25-2024 12:12 PM
I removed the "Get catalog variables" component and inserted it again and the problem was solved
07-30-2024 12:58 PM - edited 10-28-2025 08:23 AM
*** UPDATE ***
There is a solution that has not been accepted as the "official solution" but it definitely is the best one.
The problem:
You have a data pill somewhere that is broken/corrupted/mapped incorrectly.
This is typically due to removing an input that was previously used or needed, but I'm sure it happens other ways.
The solution:
Go find the data pill that's corrupted and fix it. You might have to go through each input on each step to find it, and there might be more than one.
SHOUT OUT TO @JeevesS for the solution. Go give him/her a thumbs up!
*** END UPDATE ***
I didn't have a "Get Catalog Variables" action to delete, so I just deleted everything and re-did it. Worked like a charm!
09-03-2025 03:29 PM - edited 09-03-2025 03:30 PM
I removed and disabled the "Error Handler" within sub flow, which resolved the issue. Added back "Error Handler", I was able to save and publish the sub flow successfully.
09-04-2025 07:57 AM
For me it was the "Send Email" steps. For some reason I had to remove and re-add all the data pills from the email bodies - the pills in the TO and CC fields were fine.
I was clicking through all the steps in my flow and when I clicked on the email steps it gave me another error stating an issue with the email body.
Once I fixed all of the emails in my flow, I was able to publish without this error. But try clicking each step to see if you get another error, it may tell you how to fix it.
09-11-2026 06:15 AM - edited 09-11-2026 06:16 AM
Thanks for this folks. My flow had a lot of pills in it so found the clone method really easy to use and quick. Just delete from the bottom up and save after every deletion and you will arrive at your problematic data pill.
