03-04-2018 10:54 AM
Hi . Does anyone know how to delete an KB article template ? I am at home working in dev but at work ( in test ) I began creating article templates for my employer and somehow I managed to create a situation where , when I click on create new article template I dont get the original pristine form. I get a form that has the top header but it has a prefilled template ( problem - solution ) at the bottom, a schema of a template that I had created once and now it comes up every time. I just want to revert back to a simple ,happy place where I can create KB article templates as I now am following the Servicenow directions explicitly and have no problem in dev. Somehow I messed up the table structure at work ( I think ) some how so cannot simply create a KB article template from scratch.
I would really appreciate any help. I cannot find anyway to delete any of my corrupted templates and I cannot figure how to revert back to the original knowledge base template form to start creating from scratch.
Rodger
Knowledge Management
03-04-2018 02:29 PM
Why not version them. So that you know which is the latest one. For ex. Problem - Resolution V1, Problem - Resolution V2 and so on. And keep the current one as Problem - Resolution. If the current one you want to retire tomorrow, rename it to Problem - Resolution V3 and name the current one as Problem - Resolution.
01-06-2026 12:18 PM
I ran into this issue on a new implementation. There is value in keeping your instance "clean"; i.e. removing artifacts of trial-and-error or just plain mistakes. To this end, I was able to easily remove the unwanted Knowledge Templates doing the following:
- Note the template tables being used by the unwanted templates. Check if they are unused by any other template. ("Template table" in the "kb_article_template" records.
- Add new "delete" ACLs to the "kb_article_template" and "kb_article_template_definition" tables. Versions of these already exist with "nobody" as the required role. I created new ACLs and gave it to the "admin" role.
- Delete the undesired records from the "kb_article_template" and "kb_article_template_definition" tables.
- Delete the tables noted in step 1 (listed in the sys_db_object table).
It's as simple as this. A few notes:
- You need the admin and security_admin roles to do this (and elevate to security_admin for the ACL work).
- Adding a new ACL with permissions to do what you want overrides the out-of-box ACLs, without needing to touch the latter (staying "out of the box"). (Your permission is granted by the "most permissive" ACL.)
- Of course when you're done with this, delete or deactivate the ACLs you created. I added a description to each like "Temporary delete access control on kb_article_template. Only activate if you need to delete a template rather than inactivate it.", and deactivated the ACLs when I was done. (Now we're back to out of the box for all intents and purposes.)
