How to assign assignment group as per location
RunaliP
I am working on catlog item, my requirement is when line manager approve a request then it should be assign to that particular team as per the location.
In UI there is location field if requestor will select any location .
so according to that location it should be assign to that particular location team.
For this i have to create workflow. I m trying it with Run script
please provide solution on it.
Thank You
Runjay Patel
Hi @RunaliP ,
If you have created location field on group table then use below script.
var groupSysId='';
var loc = current.variables.current_location; // Assuming "current_location" is the variable name
var gr = new GlideRecord('sys_group'); // Replace with your table name
gr.addQuery('location', loc; // Assuming location is field name in group table
if (gr.next()) {
    groupSysId = gr.sys_id;
