How to call REST Massage in Script-Background of ServiceNow
haruna naka
I made JSON on OpenWeatherMap like below and I tried to call REST Massage in Script-Background of ServiceNow by entering JSON's script below and clicking "Run Script".However I couldn't call REST Massage.
If someone knows solution, please let me know.Thanks.
[JSON]
try {
var r = new sn_ws.RESTMessageV2('application name, 'title');
r.setStringParameterNoEscape('timezoon', '322440');
var response = r.execute();
var responseBody = response.getBody();
var httpStatus = response.getStatusCode();
catch(ex) {
var message = ex.message;
Marc Mouries
you need to set the end point.
(function execute() {
    var restMessage = new sn_ws.RESTMessageV2();
    restMessage.setEndpoint('https://api.openweathermap.org/data/2.5/weather?zip='+ YOUR_ZIP_CODE +'&appid='+ YOUR_KEY);
    restMessage.setHttpMethod('get');
    var response = restMessage.execute();
    var httpResponseStatus = response.getStatusCode();
    if (httpResponseStatus == 200) {
       var responseObject = JSON.parse(responseBody);
    // do what you need to do with the response
    return body;
Hitoshi Ozawa
Hi Haruna,
I've created a REST Message and ran the script.
1. REST Message. Created a REST Message named "OpenWeatherMap" with HTTP Method name "GET" (changed the default method name).
 Executed the following script. Note that parameters to RESTMessageV2 are REST Message name and HTTP Method name that I've created above.
try {
    var r = new sn_ws.RESTMessageV2('OpenWeatherMap', 'GET');
    r.setStringParameterNoEscape('timezone', '322440');
    gs.info(responseBody);
} catch (ex) {
Execution result:
Thanks a lot!
The complete step is as follows.
  1. In the "Endpoint", use "${appid}" instead of hardcoding the application id in the url. Hardcoding app id or url in script is a bad practice.
  2. Click on "Auto-generate variables" under "Related Links". This will generate a new record under "Variable Substitution".
  3. Click "appid" and enter application id in the "Test value" field.
  4. Save the setting and click on "Test" link under Related Links to test endpoint.
https://docs.servicenow.com/bundle/sandiego-application-development/page/integrate/outbound-rest/con...
