04-24-2022 09:09 PM
I have set up Data Certification for certain fields from Incident table.
As you can see below, by reporting only on cert_element table, I am not able to add in more fields from incident table (i.e: incident.priority, incident.assignment group, incident.service_offering).
So I thought of creating a Database View to join cert_element and incident table to get the fields I need from incident table.
Which fields do I use to join cert_element table and incident table using Database View?
I have tried as below.
But getting error that ce.id is unknown.
I have checked in the cert_element table that it should be there.
ce.id is actually as below:
Any ideas here are greatly appreciated.
Thanks in advance.
Data Certification
04-24-2022 09:32 PM
Hey Dennis,
Found one related article on HI:
Description
When creating a database view it is sometimes necessary to join tables via a Document ID type field.
Like Reference fields, Document ID fields allow the record to reference another record. However, Document ID fields allow you to reference a record on any table, not just a pre-defined one like Reference fields.
This means that the data is stored in 2 fields: Table Name & Document (sys_id)
Incorrectly joining tables by only referencing the Document field can lead to unexpected outcomes like only returning partial results or, a mismatch between the row count and the results returned.
Ref link:
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0952022
04-24-2022 09:37 PM
Many thanks to Ankur and Aman !
04-24-2022 09:54 PM
Glad to help 🙂
