How to get display value of any reference field using Client script?
rathikaramamurt
Giga Expert
Hey,
Could anyone please advise on how to get the display value for any reference field (CI field) using the onSubmit Catalog Client script?
Using g_form.getValue('u_device_ref_1'), I am getting the sys_id of this field
And with g_form.getDisplayValue('u_device_ref_1'), I am getting blank value.
Thanks in Advance,
Rathika.
PrashantLearnIT
Tera Sage
HI Rathika,
You can use g_form.getDisplayBox('field_name');
Prashant
Please appreciate the efforts of community contributors by marking the appropriate response as the correct answer and helpful. This may help other community users to follow the correct solution in the future.
Cheers,
Prashant Kumar
Community Profile LinkedIn YouTube Medium TopMate
25 REPLIES 25
This worked for me hope helps you too.
var assignee = g_form.getValue('assigned_to');
var assigneeName = getDisplayValue_2('assigned_to', 'sys_display.sc_req_item.assigned_to');
// htmlID: exact HTML id from your browser's inspect window
function getDisplayValue_2(fieldName, htmlID) {
	// frontend eg. CatItem by OOB
	if (!window)
		return g_form.getDisplayValue(fieldName);
	// backend eg. RITM by OOB
	if (g_form.getDisplayBox(fieldName) && g_form.getDisplayBox(fieldName).value)
		return g_form.getDisplayBox(fieldName).value;
	// backend eg. RITM by HTML
	var el = document.getElementById(htmlID) || // try this.document... on errors
		document.querySelector('[id$="' + htmlID + '"]');
	if (!el) return '';
	var tag = el.tagName.toLowerCase();
	if (tag === 'input' || tag === 'textarea') { // reference, textbox, ...
		return el.value || '';
	if (tag === 'select') { // selectbox
		var opt = el.selectedOptions && el.selectedOptions[0];
		return opt ? opt.textContent.trim() : '';
	return el.textContent.trim() || '';
