How to select values from dropdown on portal using ATF?
09-09-2020 11:40 AM
Hi all,
How to select values from dropdown on portal?
I tried using Click Component (Custom UI) and Set Component Values (Custom UI) but ATF fails to retrieve Select from dropdown option or click on dropdown to set values
Any other ways to do this?
Thanks!
Service Portal
09-10-2020 12:34 AM
Hi Rutuja,
If this is custom portal page then if you are unable to retrieve then it cannot be selected
09-09-2020 11:36 PM
09-10-2020 12:28 AM
If its on portal, then you can use set Field Values SP. Is it not working with that?
09-10-2020 12:34 AM
No,Its not working with set Field values SP as it is on our custom application on Service Portal
Rutuja Kulkarni
09-10-2020 12:49 AM
I don't think there will be any issue with custom application as long as it SP.
Is the issue happening only with dropdown. Were you able to set values in other field types using set Field values SP?
