How to use getSCAttachmentCount in System UI -UI Script GlobalCatalogItemFunctions
klefevre
I'm using the getSCAttachmentCount function in GlobalCatalogItemFunctions to check to see if an item was attached to my request before allowing the request to be submitted.  I get the error "Failed to load resource: the server responded with a status of 404 - Not Found" when I get to the point of calling the function.  If I go to System UI | UI Scripts in the explorer window, I can find the function, so I know it exists.
When I got to Service Portal | Portals and select my portal, under Theme | JS Includes, I see GlobalCatalogItemFunctions.
What more do I need to do to get it to work?
klefevre
The issue has been solved as explained above. This question can be closed.
RAHUL Khanna1
Mega Guru
@ Author You need to close the thread.
