‎03-03-2022 11:10 PM
Hi everyone,
How do you set approval in workflow?
I would like to set the approver to be from variable?
the catalog item variable is manager and value will be from manager field.
Thanks in advanced.
Service Catalog
Service Portal
Workflow
‎03-07-2022 11:22 PM
If this workflow is on request then you should query the RITM details and use them
somethink like this.
var answer=[];
var grScReqItem = new GlideRecord('sc_req_item');
grScReqItem.addEncodedQuery("request="+current.sys_id+"^cat_item=1391a4db070630100b36f6fd7c1ed0c2");//map you catalog item sysid here.
grScReqItem.query();
if (grScReqItem.next()) {
answer.push(grScReqItem.variables.manager.toString());
for below line you should modify the highlated part with the catalog item sysid you want to fetch manager details from.
‎03-07-2022 10:40 PM
HI Freddy
are you using proper variable name ?
You should use below coode in 'Approval - user' activity.
answer=[];
answer.push(current.variables.u_manager.toString()); //give your manager variable name
Can you also check if manager details are filled or not?
‎03-07-2022 10:47 PM
‎03-07-2022 10:53 PM
Hi freddy
there is a mistake in your code,You cannot use gr as it is not defined.
use current to access the details of current record.
code:
answer=[];
answer.push(current.variables.manager.toString()); //give your manager variable name
‎03-07-2022 11:11 PM
Hi Rohila,
Thanks for your responses.
I've changed it to current.variables.manager.toString()
answer=[];
Still doesn't work.
So far it only works, if I add a user , it works
‎03-07-2022 11:15 PM
Hi
Manager is a refernce field right? can you keep logs and verify manager value.
you can also try this, both will work
answer=[];
answer.push(current.variable_pool.manager.toString());
