Using Sybase database in Flow.
Chris M3
I am wondering if anyone has successfully setup a Sybase Connection through Integration Hub/Flow.  I am attempting to setup our Netcool connection, which is currently accomplished through script includes, as flow actions.  I have setup the connection by re-enabling the Sybase database format choice, and setting the connection up in the same method as the Netcool interface.  When I attempt to do a simple query through a new action (JDBC Step), I get the below error.  I have also attempted to build the connection in-line on the action as the 'Custom' database type and received the same error.
SQLException: Cannot invoke "java.sql.Statement.setQueryTimeout(int)" because "statement" is null
Below is the connection info (sanitized), I have also tried putting com.sybase.jdbc3.jdbc.SybDriver into the JDBC driver field
Any thoughts or help would be appreciated
Hi @Chris M3 ,
Send me screenshot with all parameter visible. If you have uploaded the jar file correctly then it should work.
First screenshot is the example setting it up as a connection
And attempting to set it up inline in the custom JDBC Step
