How Many types of client scripts in ServiceNow
UdayG0047661101
Hi Family,
Can anyone tell me How Many types of client scripts in ServiceNow?
Many Thanks,
Abel Tuter
Hi @UdayG0047661101
Here All 4 client scripts with sample code as a example.
  1. Onload ()
Common Use Cases: Setting default field values, hiding or showing fields on load, or making fields read-only based on roles.
Code Example:
function onLoad() {
    if (g_form.isNewRecord()) {
                g_form.setValue('impact', '3');
               g_form.addInfoMessage('Welcome! Please fill out all necessary field details.');
  1. onChange()
Common Use Cases: Making a field mandatory based on another choice, showing a section, or validating input format.
Code Example:
    if (newValue == 'hardware') {
        g_form.setMandatory('u_serial_number', true);
        g_form.showFieldMsg('u_serial_number', 'Serial number is strictly required for hardware items.', 'info');
        g_form.setMandatory('u_serial_number', false);
3.onSubmit()
  • Common Use Cases: Final multi-field form validations or preventing submissions when formatting or security constraints are broken.
Code Example:
function onSubmit() {
    var shortDesc = g_form.getValue('short_description');
        if (shortDesc.length < 10) {
        g_form.addErrorMessage('Submission aborted: The short description must be at least 10 characters long.');
        return false;
    return true;
  1. onCellEdit()
  • Common Use Cases: Restricting mass inline updates, validating list changes, or locking down specific columns based on user status.
Code Example:
function onCellEdit(sysIDs, table, oldValues, newValue, callback) {
    var saveAndClose = true;
    if (newValue == '7') {
         alert('Security Notice: Records cannot be Closed directly via the list view view. Please open the form.');
        saveAndClose = false;
    callback(saveAndClose);
nitin gupta1
ServiceNow Client Script Types (4 Types)
1. onLoad()
- Executes when the form loads
- Used to set default values, hide/show fields, initialize form
Example:
function onLoad() {
g_form.setValue('priority', '2');
2. onChange()
- Executes when a field value changes
- Used to validate input or update other fields dynamically
Example:
if (newValue == '1') {
g_form.setValue('state', 'In Progress');
3. onSubmit()
- Executes when the form is submitted
- Used for validation before submission
Example:
if (!g_form.getValue('short_description')) {
alert('Short Description is required');
return false;
4. onCellEdit()
- Executes when a list cell is edited (list view, not form)
- Used to validate or control inline list editing
Example:
if (newValue == '') {
alert('Value cannot be empty');
return false;
