how many types of client scripts in serviceNow?
NarayanR
Giga Explorer
Hi Family,
Can anyone tell me How Many types of client scripts in serviceNow?
Many Thanks,
Ram Patil
Tanushree Maiti
Hi @NarayanR
In ServiceNow, there are four main types of Client Scripts. Each type is triggered by a specific user action or browser-side event and is used to enhance the user experience on forms and lists.
  1. onLoad()
Trigger: Executes when a form finishes loading in the browser.
Common Use Cases:
  • Setting default field values.
  • Showing or hiding fields and sections.
  • Making fields read-only or mandatory based on conditions such as user roles.
  • Initializing form behavior when the record is opened.
  1. onChange()
Trigger: Executes when the value of a specified field changes.
Common Use Cases:
  • Auto-populating related fields.
  • Displaying validation messages or alerts.
  • Dynamically showing, hiding, enabling, or disabling fields based on user selections.
  • Performing client-side validation.
Note: The isLoading parameter is commonly used to prevent the script from running while the form is still loading.
  1. onSubmit()
Trigger: Executes when a user attempts to save, submit, or update a form.
Common Use Cases:
  • Performing final validation checks before data is sent to the server.
  • Ensuring required business conditions are met.
  • Displaying confirmation messages or preventing invalid submissions.
Note: Returning false from an onSubmit Client Script prevents the form from being submitted.
  1. onCellEdit()
Trigger: Executes when a user edits a field directly within a list view using inline editing.
Common Use Cases:
  • Validating changes made from a list.
  • Enforcing data integrity rules during inline edits.
  • Controlling or restricting bulk updates.
Tanushree Maiti
Hi @NarayanR
Here All 4 client scripts with sample code as a example.
  1. Onload ()
Common Use Cases: Setting default field values, hiding or showing fields on load, or making fields read-only based on roles.
Code Example:
function onLoad() {
    if (g_form.isNewRecord()) {
                g_form.setValue('impact', '3');
               g_form.addInfoMessage('Welcome! Please fill out all necessary field details.');
  1. onChange()
Common Use Cases: Making a field mandatory based on another choice, showing a section, or validating input format.
Code Example:
    if (newValue == 'hardware') {
        g_form.setMandatory('u_serial_number', true);
        g_form.showFieldMsg('u_serial_number', 'Serial number is strictly required for hardware items.', 'info');
        g_form.setMandatory('u_serial_number', false);
3.onSubmit()
  • Common Use Cases: Final multi-field form validations or preventing submissions when formatting or security constraints are broken.
Code Example:
function onSubmit() {
    var shortDesc = g_form.getValue('short_description');
        if (shortDesc.length < 10) {
        g_form.addErrorMessage('Submission aborted: The short description must be at least 10 characters long.');
        return false;
    return true;
  1. onCellEdit()
  • Common Use Cases: Restricting mass inline updates, validating list changes, or locking down specific columns based on user status.
Code Example:
function onCellEdit(sysIDs, table, oldValues, newValue, callback) {
    var saveAndClose = true;
    if (newValue == '7') {
         alert('Security Notice: Records cannot be Closed directly via the list view view. Please open the form.');
        saveAndClose = false;
    callback(saveAndClose);
