External Content Connector - SharePoint - Where are index documents stored?
benm3
Mega Guru
I am setting up the SharePoint External Content Connector. I have ran a full document crawl and a user mapping crawl. Both have completed and have found various documents. 151 of those documents have been indexed.
My problem is creating the index and search source as I have no idea what table these 151 documents are stored on, or if they are even stored on a table?
I have looked through sys_db_object to try and find relevant tables but cannot find any. I did find the user mapping table which does contain data.
If anyone can help, it would be really appreciated.
See image below.
Yea if you go to the ais_datasource table you should see a Index called "SharePoint Online". You can't see any of the records since they aren't stored within SN but you can use the index source and link it to a search profile.
You should be able to ask Now Assist sharepoint related queries and get answers.
11 REPLIES 11
Hugh 111
Hi @kaustubhdub  ,
Big Thanks fory your help!
I had stucked in this problem for serveral days and now i finally got the answer,
Your a life saver!
Hey, @Hugh 111  no problem, i can understand as i too was stuck with the same issue,
> >Please mark my answer helpful if i was able to solve your issue, that also helps other to find the solution ✌️
Kaustubh Dubey
