Script Editor right-click options lost with Code Generation skill ?
daviddw
Hi all,
one of the most frequently used features in Script Editor, are the context menu options 'Show Documentation' (on methods), 'Show Definition' and 'Show Data' (on tables) as documented in this article;
These options seem to be lost once the 'Intelligent Code recommendations' skill is activated (on Washington DC with NA4C v25.1.2).
Instead, the following (non documented) less contextual menu options are shown;
Anyone found a workaround to get the 'Show Documentation/Definition/Data' options back in the context menu with the skill active ?
Paige Duffey
Hi David,
Did you change any of the out of the box system properties that came with Now Assist for Code Generation? I have a fairly out of the box instances with Code Gen turned on but am not experiencing the same issue. (it is Xanadu and up to date with all NA4C plugins)
One thing you might check is the version your Now Assist for Code Generation plugin is on. There were some bug patches in October, so I'd make sure you are on the latest version.
Hi Paige,
no system properties were changed. However, could it be you don’t have the now.assist.creator role to make use of active Code Generation skills?
