Can we create flow using script
Hey All,
I wanted to know that can we create flow using script in ServiceNow and which table stores which part of flow.
Diogo Ramos
Tera Sage
Hey, going directly to your question, yes you can create a flow via code, but this has to be done via the now SDK as far as I am aware, you cannot just run a script in SN and create a flow at least in a easy way.
From SDKK 4.3.0 you normally have access to the fluent FLOW API , meaning you can also use AI to generate these flows. sdk-examples/flow-sample/src/fluent/flow-trigger-catalog-item.now.ts at main · ServiceNow/sdk-exampl...
I Hope this helps !
23 REPLIES 23
PoonkodiS
Hi @Community Alums
Flow Designer is a user-friendly ServiceNow feature that lets you automate processes without writing complex code
you can script within Flow Designer in two main ways: by adding a Script step directly to a Custom Action or by toggling the Script mode within specific core actions.
Hey @PoonkodiS,
Thanks for the response but I am asking about creating flow using scripting not writing script inside the flow.
@Community Alums
  • Reduces Scripting: Avoids complex Business Rules and script includes by using a visual UI.
  • Reusability: Convert common action sequences into reusable Subflows.
