‎06-11-2026 06:02 AM
Hey All,
I wanted to know that can we create flow using script in ServiceNow and which table stores which part of flow.
‎06-17-2026 12:29 AM
Hey, going directly to your question, yes you can create a flow via code, but this has to be done via the now SDK as far as I am aware, you cannot just run a script in SN and create a flow at least in a easy way.
From SDKK 4.3.0 you normally have access to the fluent FLOW API , meaning you can also use AI to generate these flows. sdk-examples/flow-sample/src/fluent/flow-trigger-catalog-item.now.ts at main · ServiceNow/sdk-exampl...
I Hope this helps !
‎06-17-2026 12:01 AM
hey @Priyam Sharma ,
But I haven't asked for triggering or executing flow, I have asked for flow creation through scripting.
‎06-15-2026 02:49 AM
Hi @Community Alums
Instead of building the functionality from scratch, you could invoke the existing Flow from the script. Could you please clarify the exact business requirement and the expected outcome?
Hope that Helps!
‎06-16-2026 11:47 PM
Hey @PradeepReddyA ,
If I wouldn't build the flow, how will it exist and how can I invoke it, please go through the question again, I am asking flow creation through script not triggering the flow through script.
I Hope this helps !
