How we can integrate ServiceNow and PowerBI using Flow designer
02-19-2026 04:26 AM
I have a requirement where we need to integrate with ServiceNow with PoweBI how we can achive it by using Flow designer
02-19-2026 04:27 AM
02-19-2026 05:35 AM
there is a store paid app for this from ServiceNow Store
Your customer will have to purchase it
this link talks about the setup
How to Set Power BI ServiceNow Integration: Complete Guide
if your customer is not willing to pay then you will require custom API based integration for this
check with Power BI team about their API and how you can send request
02-19-2026 07:22 PM
Hope you are doing good.
02-19-2026 05:41 AM
Power BI connector is there to integrate servicenow and Power BI.
Key feature:
- Export any ServiceNow tables and fields (including Custom tables and fields)
- Include any amount of tables and fields to your Data Source
- Create any amount of Data Sources (data sets)
- There are no limitations in exported data. To reduce the server load during the export process, the application provides the server-side pagination of data over the OData protocol (limited to 1.000 rows per page)
- Advanced filtering options to manage data selection and export only the relevant information
- Robust permission settings and access management for secure data sharing
- Dot-walking mechanism for exporting Reference type data, allowing easy access and inclusion of fields from related tables
- Incremental refresh support for efficient Power BI reports and dashboards updates without reimporting the entire dataset
- Power Query support (merge ServiceNow with other data sources, transform data and load it into Power BI Desktop with no-code experience)
- Pre-typed data, eliminating the need for manual conversion to target types such as integer, boolean, decimal, etc
- Intuitive and familiar user interface through the ServiceNow portal
- Designed for high availability and performance at scale
- Qualified Technical Support Team
- Helpful User/Admin Guide
Ref:
How to Set Power BI ServiceNow Integration: Comple... - ServiceNow Community
