onchange Client script is not working for the script include
pavam
Hi, MY catalog form
Based on level3 value, level 4  choice list values will be populated.
Based on level4 value, level 5  choice list values will be populated.
Based on level5 value, level 6  choice list values will be populated.
Below is the script include.
 BusinessGroup : function(){
          gs.log(" level3 in si"+level3)
         var choices=[];
         var gr= new GlideAggregate('u_ehsvelocities');
         gr.groupBy('u_business_group');
         while (gr.next()){
            gs.log(" level3 in si in loop"+gr.u_business_group);
            choices.push (gr.getValue('u_business_group').toString());
         //return JSON.stringify(choices);
          return 'sys_idIN' +chocies;
        BusinessUnits : function(BusinessGroup){
         gs.log(" level4 business Unit"+ BusinessGroup );
         var unitchoices=[];
         var gr= new GlideRecord('u_ehsvelocities');
         gr.addQuery('u_business_group',BusinessGroup);
         while (gr.next()){
            gs.log(" level4 in while loop"+gr.u_business_unit);
          unitchoices.push (gr.getValue('u_business_unit').toString());
          return 'sys_idIN' +unitchoices;
       WorldArea : function(BusinessGroup, BusinessUnits){
         gs.log("level5 WorldArea " );
         var worldareas=[];
         gr.addQuery('u_business_unit',BusinessUnits);
         while (gr.next()){
            gs.log(" level5 in while loop"+gr.u_world_area);
         worldareas.push (gr.getValue('u_world_area').toString());
          return 'sys_idIN' +worldareas;
   getCountry : function(){
         gs.log("level6 Country " );
         var businessGroup=this.getParameter('sysparm_business_group');
          var businessUnits=this.getParameter('sysparm_business_unit');
          var worldArea=this.getParameter('sysparm_word_area');
         var buflexCountry=[];
         gr.addQuery('u_business_group',businessGroup);
         gr.addQuery('u_business_unit',businessUnits);
         gr.addQuery('u_world_area',worldArea);
         while (gr.next()){
            gs.log(" level6 in while loop"+gr.u_bu_flex);
         buflexCountry.push(gr.getValue('u_bu_flex').toString());
          //return 'sys_idIN' +buflexCountry;
          return buflexCountry.join(',');
 and below is my client script :
 alert("1");
   var level3BusinessGroup=g_form.getValue('location_of_role_assignment_as_in_the_location_tree_level_3');
    var level4Businessunit=g_form.getValue('location_of_role_assignment_as_in_the_location_tree_level_4');
    if(!level3BusinessGroup||level4Businessunit){
  alert("before entering the loop");
    var ga= new GlideAjax('GetBusinessUnitsByBusinessGroup');
    ga.addParam('sysparm_name','getCountry');
    ga.addParam('sysparm_business_group','level3BusinessGroup');
    ga.addParam('sysparm_business_unit','level4Businessunit');
    ga.addParam('sysparm_word_area',newValue);
    ga.getXMLAnswer(function (response){
        alert("in response");
        var buflexCountry=response.split(',');
        g_form.clearOptions('u_bu_flex');
        g_form.addOption('u_bu_flex','','--select Country--');
         alert("ibefore for");
        for(var i=0;i<buflexCountry.length;i++){
            g_form.addOption('u_bu_flex',buflexCountry[i],buflexCountry[i]);
            alert("in for");
        alert("after for");
 and custom table is
and the fields in the Service catalog is
level4 ,  the field type i have given is Select box, to populate the list of values on that field.
 I dont know , where i have made mistake.
method in Script include is executing , but the result is not updating on the Service catalog form.
pavam
The above screen sheet is the custom table.
 and like u said, i kept the variable as select box only to display the list of variable values.
 and the code is not working.
