UI Builder – Transform Data Broker showing “Data resource is not configured”
02-11-2026 08:47 PM - edited 02-11-2026 08:48 PM
Hi All, @Mark Roethof @Ankur Bawiskar @Ravi Gaurav
I am implementing a use case in UI Builder (Workspace) where I need to identify duplicate accounts and navigate users to a filtered list view.
We maintain user records in a custom table x_user_directory
Requirement:
When a user clicks a “Duplicate User” tile in UI Builder:
Detect duplicate accounts based on:
email
employee_number
(optionally compare with sys_user.email)
Collect duplicate record sys_ids
Navigate to the list of such records
Current Implementation
1️⃣Data Broker Server Script (Transform Type)
I created a Data Broker Server Script (Transform) with logic similar to:
(function transform(input) {
var dupRecordsMap = {};
// Duplicate check in custom table
var ga = new GlideAggregate('x_user_directory');
ga.addAggregate('COUNT', 'email');
ga.addNotNullQuery('email');
ga.groupBy('email');
ga.query();
while (ga.next()) {
if (ga.getAggregate('COUNT', 'email') > 1) {
var gr = new GlideRecord('x_user_directory');
gr.addQuery('email', ga.email);
while (gr.next()) {
dupRecordsMap[gr.getUniqueValue()] = true;
// Optional cross-check with sys_user
var userGR = new GlideRecord('sys_user');
userGR.addNotNullQuery('email');
userGR.query();
while (userGR.next()) {
var userGR = new GlideRecord('x_user_directory');
userGR.addQuery('email', userGR.email);
userGR.query();
if (userGR.getRowCount() > 1) {
dupRecordsMap[userGR.getUniqueValue()] = true;
var ids = Object.keys(dupRecordsMap);
return {
sysIds: ids.join(','),
count: ids.length
})(input);2️⃣Output Schema
Added this Output Schema:
"type": "object",
"properties": {
"sysIds": {
"type": "string"
"count": {
"type": "number"
}3️⃣ACL Configuration
Initially, I received:
ACL did not allow execution
To fix this, I created:
ACL Type: ux_data_broker
Operation: execute
Name: sys id of data broker server script
Role: admin
Now the ACL error is resolved.
UI Builder still shows:
Add details in the configuration for Duplicate Account IDs to review the data output
Please help me to understand how to navigate on required list of duplicate records.
05-15-2026 09:09 PM - edited 05-15-2026 09:12 PM
Hi Everyone,
I had faced similar issue, but it got resolved when I created the data broker in the Global scope. The issue can sometimes happen due to compatibility of the scope. In my scenario I first tried out in the background script to verify if the script was working fine so I moved ahead and changed the scope next.
If this helps, please mark it as helpful.
